as i have mentioned above,
bikes smaller odometer is giving incorrect readings, also the accuracy of speedometer is not good. so i managed to get it changed from suzuki, but now the newer meter also have the same problem, and its accuracy is also same as the earlier one.
i have checked CG125 Euro2 meter with GPS , and it barely has the error of 6-7km/h at 100+ speed, while mine has the error of around 18Km/h at the same speed.
what to do now??
should i try to change the inside of the meter with CG125's meter???
EDIT: newer meter is comparatively accurate.
my bad
