Some info about it
table cellpadding=1" cellspacing=1" width=623"
tbody
[highlight]
[highlight]
GENERAL
[/highlight]
[/highlight]
[highlight]
Body type
[/highlight]
Sedan
[highlight]
Drive
[/highlight]
FF
Transmission
4 speed automatic
Displacement, cc
1498
[highlight]
Frame
[/highlight]
GF-AE110-AEPEK(L)
Price of new car, thousands yen (Tokyo area)
1582 (~$13100)
[highlight]
[highlight]
SPECIFICATION (SPECS)
[/highlight]
[/highlight]
[highlight]
EXTERIOR
[/highlight]
Exterior dimensions (LxWxH), mm
4315 x 1690 x 1385
Interior dimensions (LxWxH), mm
1830 x 1425 x 1165
Wheel base, mm
2465
Treads (F/R), mm
1470 / 1460
Ground clearance, mm
150
Curb vehicle weight, kg
1060
Gross vehicle weight, kg
Seating capacity, persons
5
Doors number
Min.turning radius, m
4.8
Fuel tank capacity, l
50
[highlight]
ENGINE
[/highlight]
Displacement, cc
1498
[highlight]
Engine model
[/highlight]
5A-FE
Max.power (Net), kw(PS)/rpm
100 ps (73.55 kw) / 5600 rpm
Max.torque(Net), N*m(kg*m)/rpm
14.0 kg*m (137.29 N*m) / 4400 rpm
Power density
10.6
Engine type
Serial 4 cylinder DOHC16 valve
Engine information
Fuel system
EFI (electronic fuel injection)
Turbocharger
No
Fuel type
Unleaded regular gasoline
LEV system (Low emission vehicle)
No
Compression ratio
9.8
Bore, mm
78.7
Stroke, mm
77
Final gear ratio
Fuel consumption at 10-15 modes, l/100km
6.8
Fuel consumption at 60 km/h, l/100km
[highlight]
CHASSIS / TRANSMISSION
[/highlight]
Power steering
Yes
Tires size, front
185/65R14 82s
Tires size rear
185/65R14 82s
Braking system, front
Ventilated disk
Braking system, rear
Drum (leading/trailing)
Suspension system, front
Strut type coil spring
Suspension system, rear
Strut type coil spring (stabilizer attaching)
[highlight]
[highlight]
EQUIPMENT
[/highlight]
[/highlight]
[highlight]
EXTERIOR EQUIPMENT
[/highlight]
Sunroof / Moonroof
Option
Front fog lamp
Option
Rear fog lamp
Not Present
Xenon headlight (Discharge lamp)
Not Present
Projector headlight
Not Present
Rear wiper
Not Present
Front spoiler
Option
Rear or roof spoiler
Option
ABS (Antilock brake system)
Present
TCS (Traction control system)
Not Present
LSD (Limited slip differential)
Not Present
Privacy glass
Not Present
UV cutting glass
Present
Aluminium wheel
Option
[highlight]
[highlight]
INTERIOR EQUIPMENT
[/highlight]
[/highlight]
Air conditioner
Full automatic
Wood panel
Present
Cruise control
Not Present
Centralized door lock
Present
Power window
Present
Steering wheel telescopic
Not Present
Steering wheel tilt
Present
Leather steering wheel
Not Present
Power front seat
Not Present
Power rear seat
Not Present
Leather seat
Not Present
Falling down type rear seat
Not Present
Child seat fixed with seat belt
Present
Rear ELR3 point seat belt
Present
Front seat pretensioner seat belt
Present
Fourth limited front seat belt
Present
Side impact bar
Present
Airbag (Driver)
Present
Airbag (Passenger)
Present
Airbag (Side)
Not Present
Audio deck
AM/FM radio equipped cassette player
CD-player
Not Present
Car navigation system
Option
/tbody
/table
