lol no that is not the case...har jaga sciendani na mar karo jigar...
its actually pretty simple...when u pull out the RCA from amp or pre while music is playing change it and plug it back in WHEN PRE IS ON..then this happens..
when u plug RCA in while headunit in on..sudden surge goes through the RCA ( a high voltage) and this blows up the pico fuse..
and you said u soldered wire to bypass the pico fuse..well u have fixed it now...bad mein kabi dubara aesa hua..i mean removing RCA's etc while pre in on..tou ur whole headunit is gonna BURN... cause there will be NO FUSE to stop the voltage SPIKE... MARK MY WORDS !
so my way was better ..atleast u have a solid RCA ground in front of ur eyes and is EXternal..with no link to the internal PCB..hence voltage spike aaya bi tou chassis and car main cicuit mein hi rhe ga.. and will not go through the PCB !
