Can i get number from wheres you buy A.C Pipe?Is its 100% pure Cooper?Kindly Provide Contact number of Air conditioner pipe shop.and wire from where to buy air conditioner wire.kindly whatsapp me 03204782581Regards,Zeeshan
gree is best
if you know contact no kindly share
What is the desi term to ask the technician to vacuum the lines? Should I just him to use a vacuum to check for leaks and to remove any moisture that may be present? Btw do you remove moisture from the same lines that get checked for leakage?
