^what action will Indus take regarding those that do ask for Premium?
What is the Dealership asks for Premium? Kya ho gaaaaaaaa:P?
CVT Altis must come to Pakistan, and so does the 1.4L Diesel version!!!!!!!
1.4l D-4D Diesel Engine
Available with either a six-speed manual or six-speed MultiMode transmission, the Euro 5+ compliant 1.4 litre D-4D engine develops 66 kW / 90 DIN hp and maximum torque of 205 Nm at only 1,800 to 2,800 rpm.
Available with Stop & Start technology in the new Corolla, the 1.4 D-4D turbodiesel unit also benefits from improved Toyota Optimal Drive technology, maximising performance and driveability whilst minimising fuel consumption, and CO[SUB]2[/SUB] and particulate emissions.
A 2-step hydraulic control valve is installed in the timing chain cover. This has the benefit of reducing friction when hydraulic pressure is low by opening and closing the relief valve based on driving conditions.
Engine warm-up time is minimised through the installation of a coolant by-pass system that helps to reduce heat losses in engine coolant during start-up.
Piezoelectric injectors control the fuel volume and the timing of the injection more accurately. The high speed reaction time of Piezo injectors makes multi-phase high speed injection possible. This has the effect of both lowering the rate of combustion expansion and effecting a more thorough burn within the combustion chamber, thus further reducing particulate, NO[SUB]x[/SUB] and CO[SUB]2[/SUB] emissions.
This, allied to high common rail injection pressures of 160 Mpa, results in shorter injection times, combining a faster engine response with improved fuel economy and reduced CO[SUB]2[/SUB] emissions.
When equipped with a six-speed manual transmission and Stop & Start technology, the 1.4 D-4D unit returns a combined cycle fuel consumption of 3.8 l/100 km and generates CO[SUB]2[/SUB] emissions of only 99 g/km –a reduction of 26 g/km.
