the 2 speed fans require two separate relays and 2 separate inputs to work, do not try to run the full speed directly when the fan is off, it pulls an enormous amount of amps and may burn wiring or weld the relay shut, the original setup always start the fans at low speed then kick to high as required (ecu kicks it high)
Your ECU may not have the 2 spd fan control system, in which case you wasted money on the heavy duty fans.
