@aly
diff locks are availble only on the super safari model (not on all). I love the patrol and though it has rigid axle, ride is good both on and off road.
if ur really looking for nissan patrol then plz send me email. ur price range/ model etc?
@petrol
nisaan Y60 have 4.2 liters engine. fuel consumption is much batter then others like LC etc. my nissan patrol 89 do 11 to 12 liters per km.LC do 10 km. so what u say...
Performance View Full Performance Specifications
4,169 cc 4.2 liters in-line 6 engine with 96 mm bore, 96 mm stroke, 22.7 compression ratio, overhead valve and two valves per cylinder TD42Ti
Part-time 4x4-wheel drive manual hubs, manual and speed limited (manual only)
Diesel fuel
Turbo compressor
Power: 114 kW , 155 HP DIN @ 3,600 rpm; , 360 Nm @ 2,000 rpm
Emission control level - carbon dioxide level (g/km): 341
Fuel economy ADR 81/00: 12.9
Fuel consumption: AS 2877 and ADR 81/01, combined (l/100km): 12.9 and combined (mpg): 18
4.111:1 axle ratio
Rear limited slip differential
Diesel indirect injection fuel system
Beam front and rear suspension rigid with stabilizer bar and coil springs
Dimensions View Full Dimensions Specifications
95 liter, 25.1 gallon main fuel tank for diesel , 80 liter, 21.1 gallon auxiliary fuel tank for diesel
External dimensions: overall length (mm): 4,885, overall length (inches): 192.3, overall width (mm): 1,930, overall width (inches): 76, overall height (mm): 1,875, overall height (inches): 73.8, wheelbase (mm): 2,970, wheelbase (inches): 116.9, curb to curb turning circle (mm): 12,500 and curb to curb turning circle (feet): 41
Weights: gross vehicle weight rating (kg): 3,150, gross vehicle weight rating (lbs): 6,945, curb weight (kg): 2,100, curb weight (lbs): 4,630, gross trailer weight braked (kg): 2,500, gross trailer weight braked (lbs): 5,512, gross trailer weight unbraked (kg): 750, gross trailer weight unbraked (lbs): 1,653, front axle weight (kg): 1,530, front axle weight (lbs): 3,373, rear axle weight (kg): 1,800, rear axle weight (lbs): 3,968, max legal load (kg): 1,050 and max payload (lbs): 2,315
SUV specifics approach angle (degrees): 37 and departure angle (degrees): 33.5
MORE
Type 7S EST
Designer
Number of doors 5
dimensions & weight
Wheelbase 2970 mm 116.9 in
Track front 1580 mm 62.2 in
rear 1585 mm 62.4 in
Length 4845 mm 190.7 in
Width 1930 mm 76 in
Height 1800 mm 70.9 in
Length:wheelbase ratio 1.63
Ground clearance
Kerb weight 2120 kg 4674 lb
Weight distribution
(Front)
Fuel capacity 95
litres 20.9
UK Gal 25.1
US Gal
aerodynamics
Drag coefficient
Frontal Area
Cx
engine
Code
Manufacturer Nissan
Type S-6
SOHC
12 valves total
2 valves per cylinder
Main bearings
Construction
Bore × stroke 96.00mm × 96.00mm
3.78 in × 3.78 in
Bore/Stroke ratio 1
Displacement 4169 cc
(254.408 cu in)
Unitary capacity 694.83 cc/cylinder
Compression ratio 8.50:1
Fuel system
Aspiration Normal
Compressor type N/A
Intercooler None
Catalytic Converter Y
Max. output
(DIN) 172.4 PS (170.0 bhp) (126.8 kW)
@4000 rpm
Max. torque
(DIN) 320.0 Nm (236 lbft) (32.6 kgm)
@3200 rpm
Maximum rpm
Coolant Water
Specific output 40.8 bhp/litre
0.67 bhp/cu in
Specific torque 76.76 Nm/litre
performance
Note: A value of -1 means that
the car cannot attain that speed.
0-50mph (80 km/h)
0-60mph
0-100km/h
0-100mph
80-120km/h
(50-70mph)
in top
0-Quarter-mile
0-Kilometre
Top speed 160 km/h (99 mph)
Fuel Consumption
CO2 Emissions
Power-to-weight 80.19 bhp/ton
