What is the price of Liqui Moly MOS2 10W40, 4L&ZIC XQ 5W40 4L
Sent from my iPad using PW Forums
Did Zic change its engine oil names? There's no XQ or A+ or A on their website.Rather, X7, X9, X5, X3 are there mentioned.See website http://zicoil.pk/products.php?cat=GasolineCNG&main=zic
yes the names and packagings have changed. zic a+, A and 0w are renamed to zic x7 5w20, zic x7 10w40 and zic x7 0w30 respectively.zic xq has been renamed to zic x9, zic hiflo has been renamed to zic x5 and zic m has been renamed to zic x3
why cant i find shell hx7e?? Only hx7 is available now!!!!!!
Planning to change Shell HX5 10W40 with Toyota Petron 10W30... What's your opinion Sir?
Which car???
Toyota Corolla 2007, 2NZFE and 160K driven...
Which will be better Havoline Formula 10W30 or Toyota 10W30 ?
Well, u have to ensure a couple of things. The 2nzfe should be fed with the latest grades oils I.e. api sn nowadays. Shell hx5 10w40 is api sn. I dont know about petron 10w30's api grading. Go for petron only if it is api sn. Otherwise stick to hx5. However I know some oils which are better than hx5 in 10w40 category. Zic A 10w40 and castrol magnatec 10w40 are also good oils. Both are api sn
Toyota should be better but the condition is that it should be api sn
Castrol magnatec 10w40 or zic A 10w40
Thanks, which should be best oil for my car?
Goto nearby toyota showroom and have a look at their 10w30 series. There are two 10w30 by toyota, one is tin packed one and the other is petron. Check the api grading for both and then let me know
api sn/cf sae 10w30.
Patron plus is API SM/CF SAE 10W30.
Shell hx5 10w40, zic 10w40 or castrol magnactec 10w40 are better becoz they are api sn
If you can find an api sn one then it's the best
Thanks Sir, there are two types of Petron at 3S, One is API SM and one is API SN, I will go for API SN...
Ya it is imported one and is in tin can. Its the best
