Wikipedia is your friend. Apparently all D15B variants had SOHC heads, so no hope. However all D15B are 16-valve so you are luckier than Margalla owners. The performance is still very nice.
In some engines (in some parts of the world) you have the option of either 8-valve SOHC I-4 or 16-valve DOHC I-4. You can also have an option b/w 16-valve SOHC I-4 or 16-valve DOHC I-4. In the first case at least, there is a situation where the DOHC variant has twice the valves than the SOHC variant.
Bentley/Rolls Royce also favour pushrods. They are very robust and no timing belt breaking issue yay!
Very simple reason. You have one additional shaft. Plus other additional stuff. I mean since actual material (read mass=kg) is more therefore cost is more. Also, to justify DOHC vs. SOHC the design engineers must work pretty hard to optimize so there is an actual benefit in terms of power gains as compared to SOHC. Therefore more man-hours put in design = greater cost of product.
Yeah right. DOHC can be optimized to be a fuel miser but its absurd spending more to save more. So it is optimized to provide more power instead.
And this is nature's gift for us. Cheap cars have small engines and not meant to run fast so need all the grunt down there at the start. And fast cars are costly and seldom loaded with trailer/cargo and enthusiastic drivers tend to press more for high rpm and the expensive DOHC's goodness comes out there. There are seldom perfect matches in nature.
