Compression test done by Magic Motor locate in model town Lahore as this workshop was refer by some PakWheels user. Well car didn’t Omit any smoke even at morning start or even driving it fast but at time workshop guy made compression test with remove air filter he accelerate car almost full and after 3 or 4 paddle car shows smoke probably light blue. So he claim sir make few oil change quite early probably they issue will get address. But now I am planning to have proper smoke test to come up with final result.
compression test is done at cranking speed of engine, (300 rpm) - whatever is written there is not a compression test.
Its a charass test
As per discussion I read about my car compression test result I conclude it need to get it done again from a knowledgeable mechanic along with smoke test and then I will able to come up with final reason of oil reduction. Probably good to visit any good Toyota dealership at least if they will charge bit high on the other hand they will do have better, updated tools and not desi mechanic mentally to check stuff.
kindly check your PCV valve as well you can find many videos on youtube about PCV valve
Dear at time I went workshop for compression test as per my said the mechanic plug off the PCV Valve and made it clean with choke and carb cleaner (nasa) and plug on again. Yes I do have little idea I view many videos they claim due to PCV valve car consume oil so isn’t better for safety reason I change with new one.
what they call pcv valve in desi terms?
Blow valve
Aoa i have vitz car 2008 model 1.3cc i was using zic 10w40 oil engine reduce oil half dip stick after every 4800km my mechanic tell change oil to 20w50 after 2 time oil of 20w50 change engine is reducing below half dipstick car almost 1 lac90k chale he kindly jo expert ho wo mashwara d Thanks All
switch back to 10w40. half dipstick is perfectly fine
Thanks Koye idea he jis se car oil consumption kam ho jaye ?
Your engine is finished now
Better replace swap it asap
Go for compression test and share readings here.
Compression test kaha se hota he matlab mechanic karte ye kahe or se hota he ?
Any good workshop can perform that test. It will cost you around 500-700 rupees.
Thanks
I also discussed this matter with my mechanic,But he abused and threatened me,He clearly told me that if i use fully synthetic oil in my car, he will cut my throat with knife.I also complained in nearest police station, but mechanic bribed them, and now police is forcing me to comprise with my mechanic.Plz suggest me what should i do, i am very depressed because of this matter.
LOL, i am pretty sure he was being sarcastic about the mechanic's cut throat example : D
