Very nice setup. Hopefully enjoying most out of it.
Mid range?? You may be referring to the mid bass drivers. As the crossovers of MB's and tweets is separate and accepts the bi wring, bi amping method. Bi wire your cross overs and then you can flip out any tweeter or MB driver from the cross over point outputs. Do play with the cut offs and attenuation levels of the tweeter from its crossover unit.
Duplicate post
Oky guys, i have changed the position of the tweeters,now they are even more sweet sounding. They are appox 1m from Mid Bass driver and firing on one and other. Im falling in love with them as they look more beautiful and integrated part of car interior now. Suggestions are welcome:
[U]Comparing the Old and the New positions:
[/U]
Not good if they r facing down onto d dashboard. In pic looks like this. Correct me if m wrong.
Sent from my Galaxy Note using Tapatalk
No they are not facing the dashboard. They are placed on the flat surface on the door cornor, so cant be facing downwards. they are properly drilled also. They seems like this in the pic, might be some editing problem.
Put them on the A pillars facing each other and make sure nothing is in between that could cause reflections which can lead to brightness.
U shud b good then...sail panel is a very good location for tweeters among others Happy Listening
welcome to sq world and many congrats for your setup.
my tweets are also firing towards each other and i love the response on this direction though my tweets are placed on dash but not in sail.
these tweeters sound best facing each other. if you have them on the door sail panel, they will face a little down towards the dashboard. also b careful while opening doors in rainy season as water might drip on to them. not the best of locations for tweeters.
@kzaki Thankyou bro for your kind words, Its a real appreciation from me when Gurus like you and many others from audio section like the system.
@madhouse12 sir your very right, there cant be any doubt on ure statement, i have tried placing them on different locations and this location suits me well.Your advice is dually noted and will prevent them from water. This suggestion comes just at the right time as today its raining in Lahore
@roms Bro, today i have tried no q-insert for the sub and i liked the sound even more and its better then mid / low Q. Thankx for ure advice.
Thats good to know. Happy listening
Sent from my iPhone using Tapatalk
Have u tried firing the tweets towards the opposite head rests so the intersection point is just in the middle. Do try it
I have been gathering some more stuff to be added in system, few of them have been bought, Details are:Focal 165CV1 bought to replace the rear OEM speakers.
Peel and seal for dampening the front door.
0 guage Bridgestone cable with thimbles for BIG-3 or BIG-2 . Needs suggestions for this.
sir bohat alla setup hay aap ka n installation b neat hay
drill the small holes on the thimble to make em at least 5 mm wide, insert the wire through the normal hole, use a blow/welding/gas torch on the thimble and feed solder from the frilled hole till it overflows. let it cool. you will have a good contact. dont hammer em
I would further add upon madhouse12's point by saying that for reference you can see what I did in my thread with a similar 0 gauge cable.https://www.pakwheels.com/forums/car-entertainment-electronics-gps-navigation/201587-one-step-closer-sq-heaven
Suggestion noted sir. What do you suggest among Big-2 or BIG-3. Im a bit reluctant for BIG-3 because adding wire from Alternator to battery seems dangerous to me. Will BIG-2 is any good OR big-3 is the only real thing. Pl note that my system do not require that much power (appox 400Rms for sub and 75rms each for front/back stage)
