when tilt is wrong water accumalates even if u some coming out of drain pipe .. this accumulated water get sprayed inside the room due blower air .. only tilt issue
thanks for your insight. But the water always when the first installation shop people did it. Then again when it came back from warranty. You mean they fitted it wrong twice?
by the way is there any danger of this not being seen to immediately.
brother the consumer court thing has been tried here many times. I wonder if it works? By the water droplets are mini not even droplets like a light spray ....you mean this does not happen with anyone else?
Yes, an AC is not supposed to throw any amount of water back in. If it does that, it is undoing all the work the compressor is doing outside...
