Unfortunately I can't see the picture in your post (maybe attache it again?).
These Inverter based work best when they work continuously without interruption.
The operation of a non-inverter based AC is as follows:
Start ----> Compressor Starts (peak load) ----> Compressor working (average load) ----> Compressor Cuts out (Room at set temperature, nominal load) ----> Compressor starts (to reach set temperature, average load).
For an inverter AC
Start ---> Compressor Starts (peak load) ---> Compressor working (average load) ---> Room approaching set temperature (Compressor slows down, lower load) ----> Compressor stops (room at set temperature, nominal load) --->Compressor starts (to reach set temperature, lower load)
The steps in bold is what differentiates a inverter compressor from a non-inverter compressor. The former can slow itself down when it not required to work at full speed, while the latter is just on or off no matter how much cooling is required. If you have interruptions in electricity it would break the cycle and probably make the inverter AC behave like a non-inverter unit in the sense it will have to start over again.
Also not all inverter compressor are built the same. You will need to find out the exact make and model to figure out what's what. Also I would never trust the consumption label on a Chinese manufactured unit, not because they are Chinese made, but they are Chinese branded and they are capable of doing all sorts of tom foolery to make people buy their products. I was in China last year and visited 3 provinces and no matter where i was Gree were the worst performers. In fact most of their places meant for international conferences don't even have gree as their cooling solutions. No idea how it got so popular here. Maybe the commission to store owners per unit is significantly higher than others.
If I were in the market for a inverter unit, I would look at ACson, LG, Sammys, Pannys and hitachi. Get their model numbers and do some research.
