When ever you replace spark plugs or High-tension wire set put some lithium grease on both terminals. (lithium based grease is good because it will not melt)otherwise you will get corrosion because of moisure
・ Mainly used for cars. ISO type.・ 14mm dia. X L19mm length type.・ IK22 and above are for tuned engines, with a spark gap of 0.8mm.・ IK16G, IK20G, and IK22G have a solid, stainless steel gasket (mainly used with Honda engines).・ IRIDIUM TOUGH VK16, VK20, and VK22 are also on sale at the same time.・ IK□L is extended type (spark position 5mm)
application: 3 cylinder carby cars
bummppp
//youtu.be/1-p1xPYCTzQ
bumppp
can any one suggest me best performance spark plugs for cuore on petrolthanks in advance
these would work for ur car as well as ngk bpr6egp
R u sure they r the best for coure cuz money does,t mean a loot but perfomance is what i,m looking 4and how much 3 plugs will cost me?and do i need to change the wire or anything?btw thanks 4 repling soon
thanks jz thanks a lootspark plug guru jee
lol,ur welcome
Application:bmw:525i,530i,x5,z4,328i,325imercedes (amg) :cl55,sl55,c55,e55lexus: ls570suburu:imprezzatoyota:tundra,tacoma,rav4
Now thts WoW
nice plugs Jz....i remember optimum motorsport was trying to sell these for my markx but i wanted to confirmed from website n from u....went for OEM Denso iridiums which is the best of markx.....but some ppl r still running on these NGK plugs on markx :o
thankz bro yes people often give wrong plugs for the vehicles without thinking wt effect it would have on the engine,i was told these are for vitz but i searched the application which i found to be good,so i got these
Jz bhai apka pm parson se full hai
Sent from my BlackBerry 9780 using Tapatalk
u can pm now
