Jz bro do u have plugs for toyota passo? If yes then pm me price pls
Sent from my MT11i using Tapatalk 2
is ur passo 1 liter?if yes its got a 1krfe n it uses 3 denso sk20hr11,price pmd
bump....
bump...
AoaBro do u have plugs for VitZ 2008 1.0 L?Pm me the priceThx
Sent from my iPhone 4s using Tapatalk
yes i do,pmd
AoaMay be its repetitive question. But i need to know that r their any known side effects of using bosch 4 tip spark plugs in honda civic 2002 vti stock engine on cng. If yes then kindly recommend me plugs for better cng economy n effeciency.
Sent from my GT-I9300 using Tapatalk 2
if plugs are too long they will shatter inside and will cause damage,if there too short the car will buck and not burn the gas correctly4tip bosche are made of copper n there usually installed in carby cars,i would not recomend those,id recomend to use oem(company recomended) plugs If they are to long they will shatter inside the piston and cause major damage.3: If they are to short your car will buck and not burn the gas right.so if you see no symptoms and its runing right then ya need to do nothing
Today Experimented on my SDMO RES13 Natural Gas gen and results were very good.As it was not performing good though was bearing 20 25% load only.Installed a used Denso IK16 and man it was WoW. Now full load with no tension.
this thread has gone beyond cars
application: toyota Avalon,camry,rav4,highlander,sienna,venza & lexus es350,rs350,rs450
Sunday bump
jz i want to buy plugs for my mira 2006 M/T which will give the best economy. any recommendations?
replied to ur sms.
@ JZ
Hi i want plug wire set for my khyber, what will be the cost
