sending u guys specs of an original caprice 1969:
Chassis Type 4/5S SAL
Number of Doors 4
Wheelbase 3023 mm (119 in)
Front Track 1613 mm (63.5 in)
Rear Track 1607 mm (63.3 in)
Length 5486 mm (216 in)
Width 2026 mm (79.8 in)
Height 1397 mm (55 in)
Ground Clearance
Length / Wheelbase Ratio 1.81
Weight 1830 kg (4030.8 lb)
Weight Distribution (front/rear)
Engine Specifications
Engine Manufacturer GM
Engine Location Front
Engine Alignment Longitudinal
Engine Construction
Coolant Type Water
Engine Type OHV
Number of Cylinders and Placement V-8
Valves per Cylinder 2 (toplam 16 adet)
Engine Displacement 5733 cc (349.85 cu in)
Bore 101.6 mm (4 in)
Stroke 88.4 mm (3.48 in)
Bore / Stroke Ratio 1.15
Unitary Capacity 716.62 cc/cylinder (43.73 cu in/cylinder)
Number of Main Bearings 5
Compression Ratio 9 : 1
Fuel System Type 1 Ro carb
Aspiration Type Normal
Compressor Type -
Intercooler Type None
Catalytic Converter
Maximum Engine Power 250 HP (186.4 kW)
Maximum Engine Power rpm 4800 d/d
Maximum Engine Torque 468 N.m (345.4 lb.ft , 47.7 kg.m)
Maximum Engine Torque rpm 2800 d/d
Engine Torque at Max. Engine Power rpm 370.9 N.m (4800 d/d)
Power / Weight Ratio 136.6 HP/ton (101.9 W/kg)
Power / Engine Displacement Ratio 43.6 HP/litre (32.5 kW/litre)
CO2 Emissions
Fuel Consumption
Performance
0 - 80 km/h
0 - 60 mph
0 - 100 km/h
0 - 160 km/h
80 - 120 km/h (in top gear)
0 - 400 m Acceleration
0 - 1000 m Acceleration
Top Speed 177 km/h (110 mph)
Gearbox and Transmission
Transmission Type 3M
Top Gear Ratio 1 : 1
Final Drive Ratio 3.08 : 1
Drive Wheels RWD
Handling, Suspension Geometry and Brakes
Steering Type
Steering Turns (lock to lock)
Turning Circle Diameter
Suspension (front) I.CS.
Suspension (rear) LA.CS.
Brakes (front/rear) Di/Dr-S
Brake Disc Diameter (front)
Brake Disc Diameter (rear)
Wheels (front)
Wheels (rear)
Tyres (front)
Tyres (rear)
