Hello everyone sorry updating late here. Thank you Chall3ng3r, Capsat and 8502 so far.
I couldn't find Mini Pajero's own thermostat so i installed the thermostat for Cultus / Baleno. It had rubber seal so when i closed the flange it's not completely connected because the rubber seal is sitting in between but seems to be doing it's job. Temperature gauge now moves up to half about 50% to 51%. Car seems to be really more powerful now and I easily touched 120 km/hr and there was a room for 130+
But you guys know what? my problem still exist
Sometimes when I start it works perfectly and start on 1st gear but most of the times it start on 3rd gear. Engine heats up really quickly after installing thermostat like within 2 minutes or so but it seems like there is a kind of timer that's stopping car to get into 1st gear. If I wait for about 10 minutes whether Idle of moving the gears start shifting.
I checked with two mechanics and they told me I need to replace it's ECU.
I also noticed the ECU is not under the dashboard like it should be so I looked for it and found it under the hood when I opened the bonnet. It's fixed using Zip Ties near the Exhaust where all the heat is. Looks like the mechanic or previous owner placed it there to heat up quickly may be?
Also, it's been 2 days now there is a Red light on the steering wheel that is on continuously. Previously it turns off right after starting the car in few seconds.
Please, is there any one who can solve this problem?
I've already spent so much but still have the same problem
