Maintenance schedule as given in the manual of Suzuki Wagon R by Pak Suzuki:
Can someone tell me the quantity of coolant in Waggy? Im planning to replace mine with ZIC SK SUPER A coolant. So want to know should I get 4 liters or 3 bottles of 1 liter each directly from the website?
Bhaio, this may be a lame question, but does Waggy has a catalytic converter?
Aren't we always have either 28 or 30 psi in all our vehicles? Or may be I am not reading it correctly?
Below is the sticker showing type of engine oil for wagon R. But whybis it recommending both SG and SM APIs?
Recommended viscosity for PKDM Wagon R as per user manual and the sticker on the car is 10W40. How can u put 5W20 in ur Waggy?!
Bro. Every vehicle has its own air pressure value. For Swift front 33 and rear 30 psi. Guy at station always ask "agay 28 peechy 30 rakhtay hyn hum".
For wagon r 36 in four wheels.
For engine oil please go what is written in manual.
To fulfill Suzuki warranty requirement you have to use Suzuki genuine lubes.
Otherwise for better health of your vehicle you should go for synthetic lubes rather than mineral based
API SG is obsolete. Latest one is SN. It goes in alphabetical order. So G is oldest and N is latest. SM and SN both are good.
it won't change.we live in the society of selfish hotheaded retards.
Yes, that I know. That's why I was asking why they have mentioned both SG and SM in the manual?
But 36 is for stock tyres, right? i.e 145/80/R13.
But my tyres are Yokohoma 165/70/R13 ecos, what pressure should I go for? Plz share ur wisdom as I am quite particular about it.
Aoa.guys i want to know about boot space available in wagon r.can we put a baby stroller easily in diggi?Thanx..
Yes 36 with stock tires.
For others you have to find out. Suzuki does not recommend tire size larger that 145 in wagonR
Ager gari ki zaroorat per chalain to spares or consumables se profit margin to aadha reh jayega. Baqi kamar other than 3S purchases torr daygi company ki but faida consumer ka hoga. . But yeah one thing a must, always use normal logic n try to be present n take a bit pain while the car is getting attended from A to Z. In sha Allah one wont regret as its based on my personal experience of about 10 years with Toyota n Suzuki 3 S. Corolla and Mehran and now Wagonr. some bitter personal experiences made me say this.
Look on tyre wall, recommended maximum pressure for that tyre will be written on its side wall.
Then about 32
Today while going to office, as i was taking a turn i noticed the break and steering getting hard all of a sudden then i noticed that the engine had turned off by itself. I switched the ignition off and then switched it on again and it was fine. this is the first time that something like this has happened. My WR is only 20k driven and has changed spark plugs, engine oil & filter and air filter on this past weekend.Any idea what could be the problem??
when engine get off. steering and brake get hard. did you pressed the clutch while turning? may b car engine turned off due to low RPM
Went to Suzuki Islamabad, they checked but could not identify any problem. They said it could be due to some loose grip/electrical connection. Advised to drive it some more and if issue reoccurs then should come back and they will thoroughly check all electrical connections.
I have VXR. Euro tyres installed. In all the fours tyres, its written that the air pressure should be 35 psi.
