Yes same k series but more advanced and economical better pick then wagonr..
Wagon R and cultus has same engines there isnot a minute change between them both engines has same design numbers.
I stated what i heard but if you have researched it than i accept your statement brother
Both wagon r and cultus has same engine k10B the brouchers are attached which are downloaded from pak suzuki website. Absolutely no difference in their engines
Wagon R.pdf (686.5 KB)New Cultus Brochure.pdf (2.4 MB)
Same engine no difference in performance and pick just difference in average due to body shape
Cultus has improved compression ratio of 11.0 that makes its engine K-next so it has better fuel economy and acceleration.
Bro design same hay but watch deeply both engine there is a difference. Cultus engine has 11.0 compression ratio and it's more advanced and lighter then wagonr engine. Thats why its give better pick economy and accerlation.
This non-sense has been deeply discussed in New cultus thread. Both Wagon R and Cultus engines are K10B but they are not 100% same. New cultus K10b is the newer generation of older k10b also know as "Next gen k10b or k-next". Do not do the stupidity of buying new cultus engine spares for wagon r engine. They won't fit.
And do not believe in whatever bullsh*t pk suzuki writes on its website. The owner's manual printed by suzuki japan says something and pk suzuki says something else. The example is the oil viscosity.
Hi, I want power mirrors installed in my Wagon R VXL but I don't want alterations with the original side panel. Can the complete JDM panel be installed. I'm attaching a snapshot from a video I found on youtube where the owner has done the same thing.Also can the knob control be installed instead of the flat button type. Your help and suggestions will be highly appreciated!
ZAcar.pk
Aoa,
I would be getting my Wagon R VXL next week
Kindly let me know that what things should be checked while receiving the car from showroom
Moreover, how much time do the showroom people take to deliver number plates
Bro My wagon R was booked on december 5th through CSD
Should i expect tail garnish and allows?
Or you were just lucky??
Saboor is your full name saboor bhatti?
I have run stock tyres 35000KM. Should I change now? because I have wheel balanced twice to date and during last wheel balancing a good mechanic suggested me to change.
No
