JAM Motorsports Parts List
Engine:
Tomei 2.8 Stroker Kit (Done)
(87mm Tomei Piston w/Ring set)
(Tomei Connecting Rods)
(Tomei Crank)
Nismo Main Bearing (Done)
Nismo Rod Bearing (Done)
Tomei Over Sized Oil Pump (Done)
Trust Over Sized Crank Case ( Oil Pan ) (Done)
Head:
HKS 280 Cams (Done)
HKS Retainers (Done)
HKS Retainer Locks (Done)
HKS Valve Spring (Done)
Black Titanium Nitrite Valves (Done)
ARP Head Studs (Done)
Greddy Timing Belt (Done)
HKS Cam Gears/Pulleys (Done)
HKS 1.7mm Head Gaskit (Done)
Head ported/polished and shimmed (Done)
Electronics:
AEM Plug-N-Ply engine management system with built in wideband UEGO (Done)
5.0 Bar Map Sensor (Done)
Defi Guages (Done)
(Boost Guage)
(Water Temperature)
(Oil Temparature)
(Oil Pressure)
(Fuel Pressure)
(Exhaust Temprature)
(Guage Controller)
Boost controller (Done)
Turbo Timer (Done)
Fuelling:
HKS Fuel Rail (Done)
1600cc Injectors (Done)
Bosch x3 fuel pumps (Done)
Complete Fuel Line upgrade (Done)
AEM Fuel Pressure Regulator Kit (Done)
Custom Build Almunium Fuel Tank (to be Installed)
Drivetrain:
Excedy Triple Plate Clutch set (Done)
Nismo 2 Way LSD (Done)
Sequential Gear box (Future Mod)
Forced Induction:
HKS GT3240 TWIN TURBO Kit (will arrive in 2 months)
(Turbos x2)
(Exhaust Manifold)
(Actuator)
(Down Pipe)
(Neccessary fittings)
Cooling:
Trust 5' Special order Intercooler Kit for Drag (to be installed with turbos)
Aftermarket Radiator (Done)
Greddy Oil Cooler (Done)
Suspension:
D2 Fully Adjustable Shocks (Done)
Brembo Upgraded Brakes Kit (to be installed with Turbos)
Suspension is going to be upgraded by Nismo Parts
Exhaust:
HKS Dragger Complete Exhaust with CAT converter (Done)
Many upgrades are waiting to be done (soon inshallah) untill turbos are fitted and vehicle is dynoed
Those include............
Weight reduction
Roll cage
Recaro Racing Seats
Volk Bronze lightweight Wheels 18'x10'
and etc
