I bought Passo 1.3 make 2007. It was also showing O/D light blinking issue. What I observed is that whenever car engine heats up and achieves normal RPM, O/D off light starts blinking and there is problem with gear shift otherwise everything is ok.
ECU scanner displays "P1706-Torque converter abnormal".
Electrician checked all Solenoids one by one and he is saying one solenoid for O/D is faulty. where can I find this sensor in Karachi?
Attached ia picture for reference.
Interesting thing is this issue was resolved when I bypass Coolant temperature sensor. Car runs smooth and gear shifting is also normal. Only issue is that because of no feedback of temperature, Car RPM will always remain high.
I want permanent solution. Can any body guide me?
Should I go for kabli gearbox or not?
