I'm getting same average in Karachi.
I have got it from Shuba bazzar Peshawar. got it in 5700. I have replaced it today but still check engine light is ON and ECO mode if off.
[/quote]
Mechanic said , i have to replace the sensor
If you are in Isl/rwp, contact Ishaque and m sure he would be able to help you source a kabli CAT and diagnose the issues completely. 0337-7177753
Get a kabuli CAT and the one solution to all conversion.Get your CAT converter cleaned with high pressure Water and detergent and then with petrol.it will restore the car's performance.
There is a way to fool your ECU into thinking that the cat is still present at a very low cost. There are mini cats available that screw in between the original Oxygen sensor and the 'dholki'. The idea is that the gas which the Oxygen sensor smells is through the mini cat so the message that goes to the ECU is as if the cat is still present in the car. Here is the link: https://www.amazon.com/Minicat-Sensor-Spacer-Adapter-Extender/dp/B00CBKEC06
You can do more research to educate yourself further.
I removed mine 2014 passo catalyst 3 days ago and faced no issuePickup owaome Fuel average more than 16Eco working fine
Only 1 issue faced of o2 sensor when I pushed engine at high rpm which I cleared by ob2
Hi salam bahi CAT damage to nahi ho ga....30k k mila ha kabli..... Kindly guide how to clean the catalytic
Hi, My mechanic cleaned the cat of my 2014 Model Passo. But soon after that the petrol average reduced from 10.5 to 9 in Karachi City. What do you suggest me to do??Any risk you saw after removal of Cat??
acid cleaning ?no camera ?he further blocked it
What does dholki mean?is that muffler?
Sorry to jump into discussion randomly. If cleaning of converter with acid means further blockage, then I think I also have been a victim to this and suffering from heavy engine sound on normal foot. ( see my other recent post in another sub forum)
Dear All,
I have passo 2004 model, purchased last year. After purchasing i came to know that catalytic converter was not installed in it and it gave almost 6 km/l average and exhaust sound was very abnormal. After installing CAT now it gives 12 km/l on long without AC. Technical experts kindly suggest some measures, how can i improve fuel average.Thanx.
thats very good avg for 1st gen passoyou wont get better then that
Thank u for your reply.Actually many same model car owners shows their average 18 km/l on long.The car has 1 KR engine which is also in vitz and passo of same and above models and those cars also give an average of at least 15 km/l.
