Needed a few general shots to see whether touchwiz has improved or not
A useful app
Sent from my SM-G900F
Here you go
Some more
Settings
Callll
Thanks broDo share the battery life after a few days.Meanwhile i'll just wait for the update
I think battery has improved. It has been over 24 hours since I got lollipop
It also tells you expected battery drainage timings
Phone numbers are visible in your post.
In almost every screenshot you post, signal strength Is very low, always. :p.
Screen on battery drainage increases in these white backgrounds. But standby increases little bit on android 5.
I trust you guys for phone numbers.
I have signal problems at home specially in my roomWhite back ground is of lollipop
Ok jee numbers deleted now
This white background of lollipop increases battery consumption.
Dark themes are now available for lollipop on Google play store.
Infact, I use dark theme on PW Forums app too. It is very battery friendly and visibility is good, even in day light.
You are right
can anyone guide how to use 4G/LTE on Samsung Note 3??
Sent from iPhone 6 Plus using Tapatalk
do you see LTE/4G in network mode ?what is your firmware versionto check, go to settings and then About phone
Android 4.4.2No LTE/4G option in Network Mode
Change with a root explorer of your choice (e.g. Root Explorer, Solid Explorer or EF File Explorer) the value βfalseβ in filepersist.radio.lteon into βtrueβ by way of build-in text editor of the root explorer. The file is located in root/data/property. Be sure permissions of persist.radio.lteon are set to rw, after altering the file save the file and make it read-only. Reboot your phone, now you will see and be able to pick the option βLTE/WCDMA/GSM (auto connect)β in Network Mode menu. Important: before altering ANY file on your phone be sure you have a copy of the original, unaltered file!!! Advantage of this solution: even after a phone reboot the option βLTE/WCDMA/GSM (auto connect)β will remain visible/activated
try this
this one
