Hi Dear,
The recommended Piston to cylinder clearance with diameter 86.5 is 0.06mm - 0.07mm or (0.0023in - 0.0027in), provided the piston is original.
Always check the piston to cylinder clearance at room temperature. After honing the cylinder block let it cool by itself which will take a longer period of time, or cool it under tap water. Immediately after cooling it with tap water dry it with compressed air and dry piece of cloth to prevent it from rusting. Finally check the clearance again to verify with the above mentioned values.
Regards,
Shadab Ahmad Khan Lodhi
