^^hmm,,
i have just changed the sprockets,,not checked the meter or sprocket response,, i have been to murree quite a few times but never got such issue,,just this time but that's in my opinion just a co incidence,,that it happened in murre,,
will check it,, so is ur normal now?
suppose if mine doesn't returns to normal ,what r the solutions?
tappet gauge can be bought from any hardware shpop,, in raja bazar,and gawal mandi,,, there r 4 tpres of tappet gauges one is just a strip that is i think 1 foot long that gauges up to .05mm and costs 90 rs..
another is the one that mechanics use which has a bend and two sides measurement of .05mm and .08mm ,i couldn't find it easily,,
another is multi values that contains 2 inches strips of thickness ranging from .05mm to 1 mm , i ,mm using it don't re,member the cost but its cheap,, and there is another of the same type but the quality is far superior ,, that wont get any rust, u can bend twist and it wont cut,,
that's a bit hard to come across,,,, just buy either multi valued one,, that's good,,
