Shazo Brother it is always advisable whenever the EFi engine is swapped in, to change the cluster gauge with a new one which has the "Check Engine Light" indicator and which should be connected to the ECU. The tester used by the electricians is just a bulb attached with a pointed lead.
Regards
Sorry for the delay as I stated earlier I was not here. The updates are, car is still under the process of putty/sanding for removal of the slightest dents. This work is being extended so as to avoid the use of putty to cover the dents in the final paint. The Painter knows my psyche and he himself referred the car once again to the body shop when he noticed some imperfections :).
.....to be in a better position to remove the dents doors have been removed once again.
good going
great!
Nice work
With the amount of focus you are putting into details, no wonder your ride will turn out to be a real piece of work. Best of luck for the project just can't wait to see the end result. I wish I had the funds and the commitment to do something similar
Nice work so far!
sir g MASHALLAH.....loving the work so far
Great going dear....this is an awe-inspiring project...A good restoration of modern Antique car....Again great Job..
Updates sir?
Thanks to all of you :)..........
Welcome back to your home town Shehroze Brother!!!
Car has been washed thoroughly...
With first coat applied
Unlike the previous paint booth, this one is far away from the workshop but it is much cleaner and well equipped.
Outstanding work done on base of paint, it can clearly seen what kind of finish gona come.Btw i can c some jasma update mind sharing
Sent from my HTC Wildfire using Tapatalk 2
updates???
Yea bro..updates?
Waiting for updates
A very good project indeed. It keeps me reminding of Kiwi's Corolla that how he added rare utilities to his car.
