Zabardast!
Masha-Allah the car looks superb.
2 things are a must as mentioned by other fellow pakwheelers.
1: Lower it, (at-least to its original height)
2: Change the rims ASAP!
Ufff!!
I re-did my car's front in the body color instead of dull black and I still curse myself for not doing it in black color.
The above mentioned gasket is damaged in my car.
I plan to clean the taillights and will be removing them.
What should I use to seal it if the foam gasket is beyond repair?
Did you get the speedometer cluster of EXi-S aswell?
If yes then for how much?
Mujhe bhi mangwa do.
Need it for my MK-1's front crossmember bar's inner side.
