when you tune the caburettor make double sure that the carburettor cover gasket in place. It makes a great difference.
Point noted.
and please do us all a favor and get rid of these junk philips screws from the engine. Use allen head socket screws.
Yup I plan to change them, will be replacing them with hex head screws, if I'll be able to get the socket head ones then will get them.
Your painter did an excellent base paint job but what happened when he was painting the graphic? not interested in his job? - The graphic is supposed to be smooth and shiny like the paint. Anyway you are doing good.
Seeing is believing, the graphic finish is shiny and smooth just like the base paint.
You wont be able to feel any difference between the finish of the graphic and the base paint even with your hand.
The original handlebars for this motorcycle had weights in their ends to reduce vibration to the wrists. If the handlebar is not original and they are not there then find a pair from a larger motorcycle and have a couple of receptacle nuts welded in. It makes a great difference in riding comfort.
Point noted.
Thanks Imran bhai,
I'll surely contact you if I'll be needing it.
BTW do you have the side cover emblems of "Deluxe"?
As far as the tail lamp cover is concerned then I got only the outer plastic lens for Rs.400 and the remaining tail light assy along with the inner dome projector is original.
The lens is of good quality, dont know whether its original or not?
Here is it.
Any sign by which I can confirm if its original or not?
Thanks buddy!
Thanks alot for the appreciation.
Pictures are on the way.
Thanks mate!
Thanks alot for the appreciation mate!
