amps space cutouts ready during load shedding
Now we needed some space at the back of the vertical board in order to accommodate the protrusion of the Sound Streams
We needed about 2" space behind the vertical board to allow for reverse installation of Sound Streams and also for air circulation. They are going to generate considerable heat, and we plan to install four fans to ensure adequate air circulation
The Sound Stream was slightly larger than the cut out hole
I forgot to mention, we rounded out the edge of boards where they joined ....
Intizaar ...
Back space being checked
the amp cut out being widened..
We needed a tight fit, so the cut out was carefully and incrementally increased..
Loadshedding continued and Mr. Yasin worked with mobile torch
Still SS did not fit ...
Better but still not perfect
