I wanted to install the Digital Sound Processor on the amplifier rack in the trunk ... but the fiber optic cable was short ... and I did not want to install it under the seats ... so Amir found space under the CNG tank
Time to take off the central console .. the fiber optic cable is fragile and can malfunction if not routed straight
Now .. there is straight path available for the fiber optic cable between head unit and the digital sound processor
The old RCA leads coming off ..
Amir does everything very neatly ... he has tied down the cable bundle with plastic clips
Edges of the carpet back together with Velcro strip
Amir has very good set of tools ... prying open clips holding the carpet under the rear seat
For passing the fiber optic cable under the carpet .. one side of the seat bolt had to be loosed to release the carpet
Fiber Optic cable routed straight and safely ..
You must have notice that another duct present earlier has been removed .. it contained the RCA leads ... but now the RCA leads were not required to originate from the head unit .. so removed ..
Trunk stuff had to be removed for connecting the new RCA leads between the DSP and the amps
Back inside the shop
