@ Ranger_ofthe_North
Thank you doctor sb for the appreciation.
@ farazarif
OK brother noted.
@ tareen
Sir the hand brake cable will not be disturbed as in this model of suzuki, the hand brake has come in the 4X4 gear which is at it's original place. Only the following will be extended
1. Fuel pipe
2. Cylincer
3. Some wiring
4. Rear shaft
@ machine
Brother the length of the shaft has nothing to do with the torque as both it's ends rotate at the same speed irrespective of it's length. The only difference can be of flexibility which may bother its alignment. For that i may change the existing rod type shaft to a pipe type shaft.
@ fouadar
OK noted sir. Will again think about it when visit the vehicle.
