Ali you can get the seat ditto fabricated from any seat maker even seat patra is also cloned in cheap way orignal seat is hard to find and are mostly rusted or if in good shape are priced high offcourse.
archon, may be you are correct but as per piks megnetto 185 ka he hai, secondly cylender k uper kiya likha hai ye tu Ali bhai he bata sakty hain lakin even ager bore kerwa ler piston,ring, weight 200 ka dal bhi do tu on first kick bike will break its both pertol valves as head valves are different and if 200's pistons aer used the will touch the valve so it will also need the head of 200 or atleast it will need 200's valves... ab itna kuch change ker k tu shyid larka bhi larki ban he sakta hai offcourse
tu ye tu sirf machine hai
