I read this on Wikipedia;
[h=2]3ZZ-FE[/h] The 3ZZ-FE is a 1.6 L (1598 cc) incarnation built in Japan. It is found in the Asian Toyota Corolla Altis which is available in countries such as Singapore, Malaysia, Philippines, Thailand and Taiwan and in the Toyota Corolla sedan sold in Sri Lanka. In South Africa the motor can be found in the RunX 160 and Corolla 160. The entire exterior design and chassis is the same as the American Corolla. Bore is 79.0 mm and the stroke is 81.5 mm. Max. output is 109 hp (81 kW) @ 6000 rpm. Max. torque is 110 lb?ft (150 Nm) @ 3800 rpm. Features SMP pistons v/s Toyota made in 1ZZ-FE engine. Uses 10W40 semi synthetic lubricant.
