Btw can anyone tell me the reason of this blown head gasket? I never heated the car so much.
Secondly I'm facing an issue.
The check engine wire on ecu pin outs when connected doesn't glows the check engine light on ignition on and but when i ground check engine light wire of meter it works fine.
Voltmeter readings suggest that chk wire is showing zero volts on ignition on but why it is not glowing the chk engine light?
As we all know when we turn the ignition on the battery oil and all lights such as abs and. Check engine appear.
And. If everything is working fine they disappear.
So im unable to get. Check engine connectd.
