the tightening values are this - convert to Nm if required
stage 1 = 15 lb/ft
stage 2 = 36 lb/ft
stage 3 = 49 lb/ft
stage 4 = retighten bolt 1 and 2 to 49 lb/ft again after 10 minutes
bolt sequence
7 6 1 3 X
9 4 2 5 8
the bolt threads should be buffed clean and the bolt holes should be run with a tap (aka tub in local mechanic language) - to clean those threads too - the bolt threads should be oiled very lightly - 1 drop of singer machine oil on them before inserting them into the holes, when they are 99% in their holes - put a drop of engine oil on the washers, now tighten in the stages mentioned above.
btw there is no Honda part no. for any sort of fiber heaggasket for this engine, There is only a metal headgasket. Its only one time useable as it has ridges on it that actually seal the head to the block.
