98k for 2014 model or the 13 model? 98k is not a much discount for an 13 model. You can get this price easily after little bargaining. If they are selling the 14 model then this is a head turner.
Yes please check the frame thoroughly. The main tip to check that the tank should be in the center of the frame check the attached picture. you can see the tank is towards right. Even the handle touches it. This is a big fault It will vibrate like hell.
Another fault that you can't check in a new bike because they won't let you to. That the center bolt there head it connected with the frame is not fitted properly. Zabardasti ghusaya hua hota hai.
This zabardasti did this to bolts after few months use.
no doubt that Ravi after sales supported a lot and changed all bolts and plate after making the whole bigger. But the thing is why did it happened at the first place? and if i won't ask my mechanic to open it so i can test what happens to vibration if i totally remove these bolts, i would never knew it in easy way. This thing would break the bolts then the frame itself slowly.
So consider these aspect while you are checking the bike for purchase.
i never intend to put these pics online but now as i was ask for an advice so i thought i should clearly mention what i faced. So other may aware of it. RP is an awesome bike but Ravi's production is mishandling it.
I guess this is enough to shake some hardcore believes in RP local assembly line
@vickytulla @mqsdrana @neodescorpio @abobobilly
