That is insane! Do you wish to destroy his car? Never advise someone without prior sound knowledge. Pure thick coolant will cause his car engine to heat up and seize.
Pure ethylene glycol is a poor conductor of heat. We use it to lower the freezing point of pure water and because of its anti corrosive properties. Infact, water is the best heat conductor. Even in sub-zero temperatures, a 50/50 coolant/water mix would suffice, it has a freezing point of upto -37C so your nathiagali temps are child's play. Even if you constantly live in sub-zero temperatures, it is best never to go beyond the 65/35 ratio.
