I have decided to give chance to the Fusion's prime amp which was lying with me and that is Fusion NV 16001. Remember its the old amp discontinued back in 2007 but still the copies are being made here in Pakistan.
Fusion NV 16001 Monoblock Amplifier
Bi-Metallic Thermal Venting System
Features two levels of heat dispersion through a combination of alloys with complimentary thermal transfer properties
One-Piece Cast Structure
This reinforced bi-metallic cast structure provides extreme strength, rigidity and protection in the extreme SPL ranges
Recessed Anchor Points
Robust industrial standard mounting feet with discretely recessed anchor points to provide clean, secure and resilient installation
Multiple Fuse Protection
Multiple fuses protect internal components and are easily accessible for quick changes in a competitive environment
Product Specifications
450 Watts RMS x 1 Channel @ 4 Ohms and 1% THD+N
755 Watts RMS x 1 Channel @ 2 Ohms and 1% THD+N
1100 Watts RMS x 1 Channel @ 1 Ohms and 1% THD+N
Linked Power Ratings @ 14.4VDC
1000 Watts RMS x 1 Channel @ 4 Ohms and 1% THD+N
1800 Watts RMS x 1 Channel @ 2 Ohms and 1% THD+N
Max Power Rating: 1600
Max Current: 100A
Full Rated Power Distortion (Max) 1kHz: 0.49%
THD @ Rated Power 1kHz/100Hz: 0.3%
Frequency Response Hz (-3dB): 10Hz - 250Hz
Signal to Noise: >90
Variable Low Pass Filter: 24 dB/Octave
Bass Boost @ 45Hz: 12dB
Input Sensitivity: 0.2 - 8V
Input Impedance: 47K
Fuse Rating: 25A x 4
