you are included yes...
250cc engine 167MM(CG250 water cooled - OHV)
Model : ZS167MM (CG250 water-cooled)
Manufacturer : Loncin
Type : Single-cylinder, vertical, water-cooled, four-stroke
Rated power and corresponding speed kW / (r / min)12.8/7000 (1 ? 5%)
Maximum torque and corresponding speed N ? m / (r / min)17.5+/5500 (1 ? 5%)
Total displacement ml : 229.2
Minimum Idling speed r / min1400 ? 100
Cylinder diameter mm67
Piston stroke mm65
Compression ratio10.0:1
Ignition timing
Before TDC 15 ? (1400r/min)Inlet
The following set camshaft
Ignition : C.D.I electronic ignition
Lubrication : Pressure, splash compound
Valve Timing"Air (when raised 1mm) Open: 2.5 ? before top dead center off: 20 ? after BDC,
Exhaust (when raised 1mm) Open: BDC ago: 30 ? off: the only point 0 ? "valve clearance mm0.05 ? 0.01
Clutch type : Manual wet multi-plate
Gear Shift Change file mode : Constant mesh five-speed two-stage variable speed drive
Reduction ratio"Primary: 3.333; a file: 2.909,Second gear: 1.867; third gear: 1.389,Fourth gear: 1.150; five files: 0.9545 "
Starting method : Electric starter
Spark Plug Type And D8TC, spark plugs with flat seating and equivalent models
Gasoline brands Equivalent models with ≥ RQ90
Oil grade Equivalent models with SF 15W/40ML total capacity of oil1100
Dimensions mm358 ? 355 ? 450Net mass kg34
Starter motorMQ1602 models with equivalent power 600WMagnetoCFW12V18A equivalent, non-contact type external rotor flywheel, 200W
Other Engine is 171FMN @mfaizandawood can you help me googling its specs.... ajj saaf saaf piece alag ker don ga apky or @onefifty k liye... beucase one u two are left .. @right now @angel82 is getting it fitted in his RP already ... so that he can challenge Typhooon
