wow nice kept machine you came to PW after some really long time.
Thanks vick bhai. Yes i came back after a long time
Sent from my GT-I9100 using PW Forums mobile app
Ap aye aur milay b nahi. V badddSent from my HTC Desire HD A9191 using PW Forums mobile app
Sach bolon ? wapsi per milna tha but barish nay mat mar dee thee so we decided no to Stop beshak @omer85 say poch lo mene usko bhi milna tha Documentation kuch bike ki rehti thee but we went straight to GTRoad.
Hum lahoriyaon ki Barish ny achi khasi taking ki huwi thee tu socha bahter hai is waqt hum dry hain Dry he is area say nikal jien as we knew barish humaray peechy peechy arahi theee
Haw haye sara secret plan das ditta. chalo koi gal nai. yesss i am pretty excited for that That's the real modification not just SHOW BIKE
he he he h he he h he he he
@vickytulla ... aap sa aik infrmtn chaiya .... sprk plug indicatin mn lekha hota ha (rning cold or too cold ) is sa kya murad hai..???? orhonda cg 125 ka valve gap ktna hota hai . 0.05 or 0.08..tnx
Ye tu kisi CG125 repiar manual say he pta chal sakay ga dost.
oor regarding sparkplug ????
running Cold ya To Cold for plugs is when they are working under there optimum temperatures.
The rusty out come of rainy tour!
plug heat range is the key in thisi do not know what is the heat range for cg plugs but if it is of 7 heat range then by using 8 or 9 heat range plug can run the engine cold or too cold, proper heat range plug would be a key for the performance,
Rain dirt is killer for any motorcycle it can cause rust in no time :(
@eur0_2 listen to the gurus here ..
hmm ..tnx guru.. currently using NGK DP8EA-9 for cg 125 E2 .. i don't knw k ya theek hai ya ni
Can anyone suggest NGK Platinum plug for Piaggio? Have anyone tested it? Any performance difference?
@silver_knife is using may be he can tell ...
i am not guru btw.....do you know which is stock plug of cg? in your current plug DP8EA the numerical digit 8 is the heat range of the plugcheck cg,s plug and find the accurate heat range if it has 8 heat range then your current plug heat range is correct by lowering the number as like 7 you would have hotter plug and by higher number as like 9 heat range plugs would be cooler then 8 or 7 heat ranges of plugsso the key is to use accurate heat range plug which is recommended by the manufacturermostly 8 heat ranges would be suitable for 125cc engines in 2 stroke bikeslike Kawasaki GTO125 stock plg is NGK B8ES
bro why dont you get the exhaust heat coated colour or plate it ?
HeheheWaqar bhai had his exhaust painted with a special paint that bakes itself in the heat. Not only did the magical paint bake itself, it even changed its color to a rusty brown one when it rained:p:p
