How you guy's are doing compression test?
Another guy got the compression test and he got same values as your test...
The limits for Suzuki G10 are 156psi min dry test and normal is 190-199psi can't remember this value exactly.
When i got the compression test at about 2 lac 70 thousand km factory sealed engine. Values came out to be around 135psi for dry test all three cylinders and after getting the overhaul done values were near 200psi for dry test.
