03-11-08
Works Done.....!!
Fuel Tank Opened Again And Checked For Weak Pump And Reasons Of Not Enough Fuel Supply To Engine....!!
Fuel Pump Level Is All Fine Along With Healthy Fuel Pump....!! Rubber Pipe Replaced With Fresh One As Old One Gets Weak...!! Blocked One Hole Also On Top Of Tank Which We Find While We Put It Down.....!!
New Fuse Box In Engine Bay Fixed..
Gear Oil Is Replaced With Mobil 1 80-90W Type....!!
Well Plans Are Now To Add Adjustable FPR So That We Can Adjust It A/c To Our Need....!! Since Pump Either Flows Too High If We Use Some Mighty Pump Or Normal 1.6L Pump Flows Lil Low So Adjustable FPR Is What We Will Go For Now To Get Rid Of All These Things.....!!!
After Drive....I Fell Cars Reposing Quiet Nicely As Compared To Earlier....!!
We Will Add Others Things Now And I Hope This All Will Get Good ...!!
Upcoming WorkOut Plans
Installing Adjustable FPR
VSS Need To Be Sorted Out Also.....Either We Swap AE101 Cluster Or Find Some 86 Auto Speedo Face To Get VSS Thing....!!
Recaro's Need To Be Fitted..
Work On Stiff Suspension
Sorry But No Pics I Can Take Today Due To Getting Busy Myself In Work Also....!!
Next Progresses Will Be Posted Along With Pics INSHALLAH
Regards
