lo yaar...just for @ahmed irfan bhai...
Open the hood
Flush all windwasherfluid, make sure it is empty
Take windwasherfluid hose off, on the end where it sprays.
Remove the air filter and position the windwasherhose JUST above the throttle. Fasten it with a tie wrap, to make sure it stays there.... Or cut a small hole in the plastic above the carburettor. Works best with down draft carburettors or SPI injection units!. Put airfilter back.
Fill Windwasher with cheap (thin!) oil... Sunfloweroil works pretty good! By heating the oil it will become thinner, so if you are not sure if it is thin enough, just heat it up a little. Do not use use old motor oil, that is way tooo thick.,.,.,
Start engine, rev it above 3000rpm, keep it there and try to wash your windscreen!
hav fun!
koi kit ki zarurat nai...n this iz wat the vitz person hz got there...
