denso ik20 is the oem aka company recomended plug for ur swifts m13a engine for best performance n economy
JZMany thnks for your prompt helpAny idea where to get them .....price idea ?thnks brother !
ur welcome bro,i sent u a pm regarding the details u can get em from me if u want
@jzdo you have NJK IFR6J11 plugs ?
nope but i have izfr6k11,i can let u know tomorrow,but please tell me ur application so i can tell if this is the right plug or not for ur car,to what i know these are for daihatsu cars only,specifically for move or for mira
I have Civic-1988 with stock 1200 c.c engine. Presently using BERU 4-Tips Plugs with stock plug wires. What do you recommend me for better pick & fuel economy ?
do u know the engine code?im assuming its carby n not efi?please confirm details so i can recomend
Yes, you r right. Its a Carby 1200 c.c engine & not EFI. I don't know the engine code. Do mention the code if u know.
engine code is d12 plugs u can use are ngk platinums bpr5rgp
Thanks for the suggestion. What about the plug wires, should i keep the stock one. Also pls tell me from where the plugs you mentioned can be purchased in Rwp/Isb and what will be the price of set of 4.
depends on the type or wires u have at the moment
well u can also gor for NGK IX iridiums and 10.2mm wires as we are using it in one 88 civic which has D12b and that thing is now preety fast gives tough time to brand new XLI and old shap city
if too short the flame propagation will be slowed down which is recorded as a weaker push on the crank depending on the ignition advance angle.
if the plug wont fire you might get cross firing in the distributor cap or shorting on the plug wire itself - once the ignition coil has dumped its field it HAS to discharge somewhere
thankz for correcting me there
hi every body i have VITZ 2002 auto trans please guide me what kind of plugs are best for vitz.
denso ik16 or ik20im using them in my vitz as well
Any update on these plugs?.. As per the owners manual for Suzuki Swift 2010, NJK IFR6J11 are the recommended iridium plugs for the car.
yup these are avaliable for 4.4k& plz look at last 2 applications on the link given below http://www.globaldenso.com/cgi-bin/global/plug/jpn/4w/4w-plug.cgi?action=search&filename=maker2car.csv&name=&cc=&FF=100denso ik16 & ik20 r recomended,only diff between these 2 is that ik20 is 6 heat range n ik16 is 5
Dear, Can u tell me the Stock Plugs and Platinum Plugs for Khyber G-10 ( Brand Wise respectively)1. NGK2. Denso3. BoschIts Urgent plz reply!
^^^^ also do tell if 10mm spark plug wires do any good to increase khyber's pik and little bit of mileage
