Salam brother @mgalaxy3
The limit is 15,00,000/- PKR, you get 30,000 bonus skywards points on yearly basis ( you will only get these if you travel often in emirates during the year ). You get 4 skyward points per 100 PKR on every transaction ( excluding any ATM transaction or bank transfers ) and other services that the card offer is worldwide lounge access on airports, complimentary pickup and drop off.
If you would like to apply for the card you should be having a salary of atleast 500,000 PKR or if you're having a business then you require 10,00,000 monthly other than this if would like to waive the fee's that is charged yearly and monthly both for that you should be priority client of SCB which means you should be having an account in SCB UAE and SCB PAK both and a balance of 10,000,000/- ( 1 Crore )
SCB UAE is not a mandatory requirement but you should be having a minimum balance as per mentioned above.
