I wrote the above post for ali on 2010 now coming to your @Moa88 deal as its 70K driven make sure all the above things were done on 40K maintenance, if the seller( current owner ) is like me, he should logged every thing on log book, so make sure to inspect the log book otherwise you only have to trust his words which is :S .... anyway if any doubt you need to do it your self as you have to do it on 80K, but before this pre maintenance confirmation you need to test her to check that all the sensors are working properly.
Put her on "D" and drive normally as any other automatic car & she suppose to act any normal automatic car expect as she is CVT, so when you change her gears by your right fool through accelerator she perform very smooth unlike conventional automatic gear box, CVT has no jerk.
Now press the 7-speed mode button, you will see the gear number , now drive it normally as an auto car and you will notice the gears will display for you.
Now test her pick up by kicking her down so you can check the VTC working & CVT is in good condition as while acceleration you will not feel any jerk of gear changing, it should be continuous acceleration all the way.
Now coming to Manual 7-speed mode testing press 7speed mode button and press +- button and you will see "M" along with the gear# , now she is in manual mode , the two main sensors you need to check is that while accelerating when RPM reach @6000 the next gear should shift automatically
even if you wont change the gear , and same should happen when you break down from 7th gear to dead stop , gears should decrease automatically even if you wont press - to decrease them, also use +- button to drive it normally.
Now put her in "S" mode and drive , you suppose to fell that she is running in low gear's to give you more torque this "S" stands for "second" like you have D2 in other auto cars for hilly areas , ascending or descending.
Check the inter loc of auto gear shiftier lever is working properly
otherwise I hope you will inspect her body and other visual checks regarding papers and other things
Good Luck
