Get it checked from a 3 S Honda and always use Honda CVT transmission oil. It is a wonderful car you will enjoy it. Inn Shaa Allah.
Thank you so much guys
Can someone please share honda citys bonnet rod and its holder pictures. I didnt get response from the city fan club.
I am fixing a 2008 City I got its rod and clip from scrap. I made sure the rod was from facelift model. But something doesnt seems right please check I am attaching pictures too
Do post some pictures when/if you do purchase it.
I did this DIY for Steermatic this might be helpful.
Any steermatic in clean condition for sale available in pindi Islamabad? looking to buy one, thanks for your help.
Have you bought the car?
hi every one.please tell which gear OIL is best for the my city steermatic...??? need help!
Genuine Honda CVT transmission fluid. Buy from a Honda dealership.
Hellow sir basically I have a question regarding honda city idsi 2006 there is steering checking light coming in my car and steering is not working properly what's the reason behind it right now I am not using it and I dont want to go to outside mechanic without information secondly I want to change the gear oil of my car what grade is required or which oil should I have to Purschae what's the capacity of my gear box can u help me regarding this
eps recalibrateu can shorten pin 4 and 9 of obd port and do eps reset procedure. get from googleand after this if eps come again after some driving simply change all wires from eps ecu to steering rack. remember mechanic try to change eps ecu and rack but u will drain yur money.2006 eps motor is hard to burn easily so plz do this first
Did you find the solution to this problem? Please share it.
I have steermatic 07 model . Just bought last month after regular oil change and service . Mechanic asked me to tune it up for better feul consumption and smooth drive. As he opened up he found oil over plugs and coils . Can it be a problem? Today i crossed 120 it felt like bubbling. Coild it be some sort of serious issue like rings or engine.... On meter its around 140k driven
Bubbling is normally related to wheel balancing and in some cases a suspension issue. If the car is loosing acceleration, then CAT could be the possible culprit. 140k on ODO is nothing for these cars, if kept sanely.
Its giving pathetic fuel average of 10,11 on long
Could be bad rings causing the leakage. Should not happen at 140k unless the car has been abused or the mileage tampered. For mileage have it tuned, throttle body serviced, charging plugs and have it scanned. Wish you all the best!
Plugs changed, throttle body cleaned . May be rings are next to look for ..... How much it"ll cost to get new rings installed
Hello. I got the fan box of honda fit from bilal ganj Oct 2020 for Rs 1000. It is exactly same article as City. Now i am able to change cabin filter.
Hi experts, i am thinking to change gear oil of my Steermatic, from where should i get it changed in isb? Estimated costs.. TIA
From any Honda 3S workshop. Pls use genuine Honda CVT transmission fluid. Not sure about cost.
