Heating Solution for Winters, Electric and Gas Blower Heater, Once in all Solution
Winters have been come. Everybody needs heating and usually Peoples in Pakistan use conventional gas heater, which poses certain hazards like improper combustion, un-burned gas venting in room in case of Gas load shedding especially in the case when peoples forgot to switch off heater and ultimately fatalities. Below is an comparison of conventional gas heater and Electric and Gas Blower Heater. Electric and Gas Blower Heater is recommended, forget about conventional gas heater.
Conventional Gas Heater
FACTS- Conventional Gas Heater
-Low capital cost (PKR 500 starting)
- Low maintenance cost in case of any problem
-Very high natural gas consumption
- Usually run on Natural Gas Only
-No automatic shutdown mechanism in case of gas load-shedding until you go for Rinnai Heaters which costs you around PKR 20,000 to 35,000 PKR
- Improper combustion of gas give nuisance in room, usually 50-60% combustion takes place only
- O2 depletion in room
- High gas bills on monthly basis
-Not safe for adults especially infants
FACTS- Electric and Gas Blower Heater
-Starting price 3500 and goes till PKR 60000 in case of brand new. Dont go for new, simply go for imported models. You can get easily in 5000 PKR range.
- Very energy efficient, consumes 90% less gas as compared to conventional heaters
- Pilot flame lit inside heater body , pilot flame heats up copper rod, electric blower blows away hot air stream
- Electric blow electricity consumption in only around 5-10 watts
- No smell in room at all
- electric supply can be provided even from UPS
- Auto power shutoff in case of low gas pressure or electricity failure
-Fail safe trip design
- Temp set point option
-Blower speed control option
-Auto ignition mechanism, no match box or lighter needed
- Safe for kids and aduts
-Able to run on natural gas/LPG too
- Very high heat transfer rates to atmosphere due to blower variable speed
- In just 15-20 mins room temp will tend to rise
- Auto blower control and heat control in auto models w.r.t temp setting
