Option for Flooring
1-Marble (e.g Jet Black, Golden, Booti Seena, Verona, Ziarat and may more .............)
2- Granite Tiles (A huge range available from SONEX, MASTER, CHINESE, UAE RAK Tile, SPANISH, ITALIAN and many more...................................)
3- Granite (Local , Imported)
Below is the comparison
-Good marble ranges from 50 Rs /Sq ft till 250 Rs/Sq ft) depends upon variety you choose
-Initially needs polish and also needs polish on regular basis
-Final looks will be clean but will dim with passage of every day
-More reliable than tiles in terms of strength
-Almost same cost as of tile if you use tile between range of 1100-1300 Rs/Sq Meter.
-Huge variety available as compared to of Marble. In Marble 10-15 flooring designs available, in world of tiles you can have thousands of designs
-Always choose granite tile for flooring
-Local good tiles are of Master and Sonex and Stile
-Prefer Matt tiles due to slipping issues
- In Baths always go for matt tiles
-Locally good tiles available in range of 800-1000 Per Sq Meter for Baths and 800-1600 Per Sq Meter for floors
-Now days china wooden texture granite tiles also available ranging from 1100 - 1450 Rs Per Sq meter, size is 5" by 32". You can also use that
-Give you statement of the art finishing
-No need of polishing on regular basis
- If you maintain , clean tile, it will be long lasting even for 20 years.
-Overall neat and clean looks after installation
Reference picture of Chinese Granite Tiles, used very extensively now days.
-Very high capital costs, you can go for it if you afford. There are no demerits. Cost ranges from 300 Rs Per Sq ft to 1000 Rs Per Sq ft, depends upon for which variety you go.
As an routine practice, or trend as per now days, simply go for the Tiles.Or decide as per the above analysis.
Thanks.
