Reply By : geforce on 5/9/2009 9:49:08 AM
how much will it cost for every thing?
maximum 2000 3000 (0 gauge wire is expansive)
Reply By : geforce on 5/9/2009 9:51:23 AM
except tools ,
wires and conector and fuse , how much A fuse do i need for small car?
u put 300A , i dont think so , over all current in this system reaches 300A max
so it will never burn , unless u give a short circuit to it
a 0 gauge wire accomodates 300ampere fuse \
Reply By : geforce on 5/9/2009 9:54:59 AM
.It can be dangerous for ur amp as well .Big 3 is a group of three wires which consist of
why it can be dangerous for ur amp??
cause amplifier will start to trip , again n again unlessit gets recommended potential difference??
it may cause , fuse blown up , or transistor , etc or internal disaster
power hungry amplifiers they need PD if its power is getting low PD it means ur vehicle voltage is not stable
Reply By : geforce on 5/9/2009 9:57:10 AM
The current in your electrical system flows from your positive battery terminal to your amp, from your amp's ground to the chassis
i have read that
electron flow from negative to positive ,
go through the topic CONVENTIONAL CURRENT if u have got some good books to read
